It is currently April 17th, 2026, 2:02 pm
PostPosted: April 20th, 2021, 12:48 pm
These look like killer drivers for the price. When I was at Parts Express 2 years ago for the speaker design competition I saw the prototype of these in the form of the 15" version. Note the 19mm XMax and very low for a 15" driver the 146 liter VAS.
http://email.parts-express.com/public/v ... 000008cc5c
295-168--dayton-audio-mx15-22-spec-sheet.pdf [538.22 KiB]
Downloaded 708 times
PostPosted: April 20th, 2021, 1:29 pm
With dual voice coils one can configure the sub-woofer as Watkins dual drive.
PostPosted: April 20th, 2021, 2:56 pm
You might be able to do the Watkins alignment but the coils are equal impedance in these drivers which they are not in the Watkins driver. In truth, the woofers are capable of far more linear volume displacement than the Watkins so with DSP you should be able to blow the doors off the Watkins drivers. As far as I know the Watkins crossover is a passive way to deliver more power to the driver at resonance. However, if the driver is properly designed you should not need to do that. The fact that the impedance of a driver goes up at resonance and draws less power should be of no consequence because at resonance, mechanically the driver motor is moving the cone without much assistance from the amp. What you have to look at when resonance occurs is the Q of the driver. That will determine the response far more than the amplifier.
PostPosted: April 20th, 2021, 4:13 pm
That's the thing about theories -- they're just that -- theories. I had to replace my Watkins woofers in what is now my home theater system. I dropped in 12-inch 4-ohm dual-coil woofers from Madisound and they have been working perfectly. Running a movie like "Dunkirk" the room shutters from the deep bass pressure when bombs go off. The crossover was not changed.
PostPosted: April 20th, 2021, 5:13 pm
Not surprised that your replacement woofers worked better that the ones from Watkins.
PostPosted: April 21st, 2021, 8:55 am
I never said better. The stock woofers foam surrounds turned to goo. So I had no choice but to replace them. So far the Madisound woofer's surrounds are holding up, but at least I won't have any trouble replacing them again.
PostPosted: April 21st, 2021, 11:16 am
Walt, Another option would have been to have the foam surrounds replaced keeping the Watkins design intact? Jim had that done to woofers in a pair of Green Mtn Diamontes that had surround rot, done locally.
PostPosted: April 21st, 2021, 11:44 am
Replacing foam surrounds is pretty easy, so long as you find good replacements. I was hesitant until I did it the first time, and found that it went much easier that I imagined. I was originally concerned about voice coil misalignment, and the need to remove the dust cap and put in a spacer in the gap between the voice coil and the pole piece. However, in the end, I just left the dust cap in place and just relied on the spider keeping things concentric and just carefully fitted the surround so that it appeared concentric with the same surround thickness. The biggest pain is cleaning off the old surround. With a plastic cone it easier, but I had paper cones, so needed to be careful to not rip or tear the edge under the old surround. The glue helps to cover up minor surface peeling of the paper cone during removal. Do it once, and you find out it is not as hard as you think.
A rotted foam surround is no reason to trash a driver.
PostPosted: April 21st, 2021, 11:46 am
I thought about that just long enough until I found dual voice-coil woofers. Besides, the Watkins version had a 4-ohm and a 2-ohm coil -- not exactly the kind of load an AV receiver likes. So -- all-in-all it worked out. My music system evolved eliminating the Infinity speakers with the Watkins woofers and the amplifiers capable of driving them. So far (about 25 years now) they serve video quite well as front left & right channels -- no sub-woofer required. My video system is genuine 5.1 only without the .1.
