It is currently May 9th, 2024, 3:54 am
PostPosted: January 22nd, 2024, 8:31 pm
Available for sale is the North Creek Audio Echo Speakers system– 3.1 speakers (LCR + free sub).
The cabinet construction was overkill, all Baltic Birch plywood with 1.5” baffle. They are finished in beautiful teak veneer with three coats of Waterlox tung-oil finish.
They were lightly used in a bedroom system and never pushed hard. I had designed the Left/Right to be wall-mounted (using a recessed French cleat system) – but they work just as well on speaker stands.
They are sealed speakers and are meant to be used with a subwoofer. I can include a passive mini-subwoofer to go with these (built using the Tang Bank W5-1138MF - Voxel subwoofer) – also finished in teak veneer.
They are 10/10 in both functional and physical condition. Also included in the sale are spare pair (2) woofers (just in case you ever damage them and need a replacement).
I’ve included horizontal polar measurements from 0-80. This measurement was at 1 meter, response further away was even more smoother.
So you are essentially getting:
8 – North 13W-06S woofers
3 – North D25-06S Silk Dome Tweeter
1 - Tang Band W5-1138MF woofer
Everything is enclosed in beautiful teak Baltic Birch cabinets.
I don’t know what to ask, but I was thinking maybe $250 for everything. I'm pretty sure the veneer and baltic birch plywood cost that much.
PostPosted: January 23rd, 2024, 1:33 am
Damn, Yo! That's a smokin' deal. A muffled soundbar with no sub will set you back more than that. :-D
PostPosted: January 24th, 2024, 3:04 am
I will take them.
PostPosted: January 26th, 2024, 10:16 am
I will take them.
Hi Shashi,
Did you get my message back?
