It is currently August 26th, 2025, 7:41 am
PostPosted: April 23rd, 2018, 8:12 pm
C-Media CM108 USB receiver chip in the DAC.
http://www.qsl.net/om3cph/sb/CM108_DataSheet_v1.6.pdf
PostPosted: April 23rd, 2018, 8:59 pm
Get the driver.
PostPosted: April 24th, 2018, 2:08 am
DaveR wrote:
I believe you need a driver. If you can figure out the C-Media chip used you might find the driver here:
https://www.cmedia.com.tw/support/download_center
It's telling me that I already have the best driver.
PostPosted: April 24th, 2018, 9:19 am
If Windows is reporting it as an unknown device there is no driver. Download the driver from the link and install it.
PostPosted: April 24th, 2018, 2:58 pm
USB PnP Sound Device - "Don't support this platform"
The driver is for Windows 8 but I have Windows 7.
PostPosted: April 24th, 2018, 3:16 pm
According to the ini file the installer supports from 98 on. Try running it in compatibility mode.
PostPosted: April 25th, 2018, 3:39 am
I hooked up that little Jolida mini-DAC I had and works fine on USB. Shows up in Sound (Burr-Brown Japan PCM2702) and I can set it as default. I give up. It will play on optical but not USB.
PostPosted: April 25th, 2018, 1:29 pm
Did you try DaveR's suggestion, or just change the DAC?
PostPosted: April 25th, 2018, 2:15 pm
I can't get the Pop Pulse to work on USB with this PC. It will work on optical.
