It is currently December 1st, 2025, 3:57 pm
 Post subject: Hello from justinis
PostPosted: July 15th, 2016, 10:11 am
Hello, all! My name is Justin and I am an electrical engineer living in DC, working in Arlington. I love vintage and modern audio and visited the Capitol Audiofest 3 out of the last 4 years. This year I visited the DCAudioDIY room for the first time and found out about this forum. I'm so excited it exists and can't wait to jump in!
Past projects:
Restored Akai AP-207, Pioneer SA-6500, Marantz 1060, New Large Advent loudspeakers
Current project:
Building a 50W stereo power amp using a driver board for a Dynaco ST-70, tubes and transformers from a Heathkit AA-100
Future projects:
Marantz 2226B restoration
Current system:
Pioneer SA-6500, New Large Advent loudspeakers, Technics SL-QD33
 Post subject: Re: Hello from justinis
PostPosted: July 15th, 2016, 10:47 am
Welcome Justinis,
Those OPT transformers from the Heathkit AA-100 are excellent.
Which driver board are you using?
PostPosted: July 15th, 2016, 11:16 am
Thanks! The DIYtube one by Shannon Parks.
 Post subject: B+ Voltage too high
PostPosted: July 15th, 2016, 11:53 am
From another thread that disappeared......
Are you measuring the voltage with a load on the power supply? With no load, the voltage will rise quite a bit. Try a 10k power resistor, or something in that range, so that you are pulling 50mA or so from the PSU. You'll need a big one.... See if the voltage drops down to the specified 445-450 VDC.
Easy fixes are:
Drop a 5R4 rectifier in there.
or
Change it from capacitor-input to choke input.
Have you tried Duncan's PSU simulator? It's great for modeling the impact of component changes.
PostPosted: July 15th, 2016, 1:33 pm
Sorry, I deleted the thread cause I found an error in my calculations. Just put it back with new values: http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=665
Thanks for the tip! I do indeed have the powers supply loaded; the entire amp is built at this point.
The 5R4 is a good suggestion, thanks. I was trying to avoid it cause I thought the zeners would be cheaper/easier, but now that it's screwing up my neg supply that's probably not true anymore.
Don't understand the capacitor/choke vs choke input. Can you explain?
Thanks!
PostPosted: July 15th, 2016, 4:27 pm
Thanks!
You put the choke first, directly downstream of the rectifier, then the filter caps.
It can be Just an "L-C" filter network, or "L-C-L", or "L-C-L-C" (big C at the end).
N.B. For low-level amplifier circuits, the choke input minimizes any high frequency artifacts generated by the rectifier. This is critical for any PSU that uses solid state rectifiers.
PostPosted: July 15th, 2016, 4:42 pm
If you are running linux (probably for windows also) there are free circuit analysis (simulation) tools available. Tubes can be modeled as linear (small signal transconductance model) or non-linear (non-linear voltage controlled current sources). There are also digital design and simulation tools and pcb design tools available.
PostPosted: July 15th, 2016, 4:45 pm
Here is link to tube models in SPICE circuit simulation code -
http://www.normankoren.com/Audio/Tubemo ... ticle.html
PostPosted: July 15th, 2016, 4:51 pm
Duncan's PSU Designer is the best, IMHO.....
http://www.duncanamps.com/psud2/download.html
PostPosted: July 15th, 2016, 5:21 pm
I was thinking more of simulating the entire amplifier.
