It is currently October 17th, 2025, 12:34 pm
 Post subject: New Member
PostPosted: July 24th, 2015, 4:26 pm
Hello all this is Walt D'Ascenzo a hands-on Rabid Audiophile who uses tubes from the 1930s and surplus components from the U.S. and U.S.S.R. (now known as the Russian Federation) military and aerospace efforts.
I am a solder sniffer from way back and love Roscoe's pulled pork -- YUM!.
Cheers to all!
 Post subject: Re: New Member
PostPosted: July 25th, 2015, 12:12 am
I've heard his system a few times, each time it sings better than the last, and its amazing what Walt does with bits and pieces. Personally I think he sniffs way too much burning rosin!
 Post subject: Speaker Cable
PostPosted: July 25th, 2015, 10:53 am
I am in the middle of a new project. I have some nice Teflon Heliax communications cable that I have been sitting on for about ten years now. I will be road testing it for use as speaker cable. It has a highly polished copper clad aluminum center conductor that is suspended inside a corrugated copper tube (the shield). It has essentially an air dielectric. I have performed a trial already in terms of working it. A thermal stripper and a sharp copper tubing-cutter gets the job done. Stay tuned for the result.
 Post subject: Re: Speaker Cable
PostPosted: August 23rd, 2015, 12:09 pm
[quote="SoundMods"]I am in the middle of a new project. I have some nice Teflon Heliax communications cable that I have been sitting on for about ten years now. I will be road testing it for use as speaker cable. It has a highly polished copper clad aluminum center conductor that is suspended inside a corrugated copper tube (the shield). It has essentially an air dielectric. I have performed a trial already in terms of working it. A thermal stripper and a sharp copper tubing-cutter gets the job done. Stay tuned for the result.
The new Heliax cable has been installed now for a couple of weeks and to say it was an improvement is a gross under statement. The overall improvement is along the lines of changing out a major piece of electronics. WOW! Transparency, sound stage, bass detail, sweet treble, etc. The cable before it stood the test of time against all comers (a quad core silver/Teflon with Kapton insulation obtained from the Boeing Plant in Everest, Washington) and the Heliax blew it away -- it was no contest. :D
PostPosted: August 24th, 2015, 11:02 am
Something like this: https://www.tessco.com/products/display ... sku=429150 ?
I'm down to my last 350' or so ;)
PostPosted: August 24th, 2015, 11:20 am
Hi Roscoe!
The Heliax I used was 3/8" plenum-rated cable with an air dielectric as opposed to foam. As it happens it fit PL-259 connectors perfectly.
I have the brochure to review but your system does not allow <*.pdf> files. ???
PostPosted: August 24th, 2015, 12:55 pm
The forum should allow .pdf files at this point, but NOT in the new user introductions section. Start a new thread in project discussions, and you should be OK...
PostPosted: August 24th, 2015, 1:04 pm
Do I get some Pulled Pork to go? :lol:
PostPosted: August 24th, 2015, 1:13 pm
I saved a sandwich from Roscoe's...trade ya for a matched quartet of caps.
