It is currently November 22nd, 2026, 9:10 am
PostPosted: November 20th, 2026, 1:15 am
https://thorstenloeschaudio.pages.dev/a ... -progress/
PostPosted: November 20th, 2026, 8:42 am
Roscoe,
Thanks. Some good interesting stuff there. I remember alot of the discussion about the ideal 300B design from TL on the various discussion boards from a couple of decades ago, particularily his preference for pentode drivers as well as the "Full Monkey" approach. Good that he consolidated his explorations and thinking in one place. Just remember, friends don't let friends use cascaded 6SN7s to drive a 300B.
PostPosted: November 21st, 2026, 9:52 am
This is very interesting.
Have the Van Alstine Audio ABX boxes I use to just AB two pieces to hear the difference in as close to realtime as possible. Switching gear takes to long for audio memory.
About ready to try this with two versions of the XLR to RCA active converters to hear the differences between the Sparkos Labs SS2590 and Staccato OSH-S discrete opamps.
PostPosted: November 21st, 2026, 4:05 pm
The following that Richard Feynman said in his presentation is worth remembering: "The first principle is that you must not fool yourself—and you are the easiest person to fool. So you have to be very careful about that." My first rule in life is don't lie. My second rule is that if you are going to violate rule one, don't be foolish enough to do it to yourself.
My word on ABX testing. It is very difficult to set up a valid double blind test. It is easy to overlook small set up errors that can lead to false positive results. With the appropriate effort and caution a valid double blind test can be done. However, very often the expectations of the test are wrong. First, the test is only about the ability to hear differences in the devices under test, not make a value judgment of the devices. That is a totally different and very personal situation. Second, it is extremely difficult to prove a null hypothesis, that is there is no difference between the devices. The best you can decide is that during that test with those listeners with that equipment and music, no difference was heard. That might change with different listeners and music. However, if a number of tests are done with different listeners, music, locations, etc. and no differences are statistically detected, you have to ask yourself if any differences that may exist are significant enough to pick either A or B.
If the test is properly run and a statically significant difference is recorded, you can go to the bank that there is an audible difference. This says nothing about quality differences or sound preferences because again that is a totally different issue.
At the end of the day, regardless of what you do, whether based on science or pure emotion, if the end result doesn't make you happy, why bother. You should not allow anyone else tell you what the sound should be. That is up to you.
