It is currently November 22nd, 2026, 9:18 am
PostPosted: November 17th, 2026, 6:48 pm
The AES/Cary Superamp DJH P-P amp was running fine with EL34 tube. Got the Linlai ZX-KT88 tubes. They are blowing the tube fuse. Manual says, set the bias to 150mA. I can see the current rapidly increase from 0mA until the fuse flows. Adjusting the bias to all the way to min setting is still causing the problem. NO such problems with EL-34 tubes. Earlier I used the amp with KT-66 tubes without issues.
Does it mean the Linlai KT-88s are bad?
Anyone can help me test them?
PostPosted: November 18th, 2026, 12:01 am
Shashi,
Can the bias supply provide enough negative voltage for KT88 tubes. EL34 and KT66 need lower bias voltage (around -35V or so), whereas KT-88 needs around -55V. This of course depends on the operating point. Too low of a bias voltage can cause the runaway condition you are having. Nothing wrong with the tube if the bias supply isn't designed for it.
P.S. Just looked at the MKII manual. It does say the amp is capable of running KT88 tubes, but it is still possible the bias supply is borderline for the tubes. Also, it appears the biasing arrangement assumes a matched quad, so a bad tube could cause a runaway condition. Do you have EL34s handy to see if they bias up properly?
P.P.S. Should have read what you stated up front, the EL34s run fine in the amp. I would tend to stick with the "low" bias tubes.
PostPosted: November 18th, 2026, 1:06 am
Shashi,
What David said. Otherwise my experience with KT-88s was that the optimum cathode current for best sound was 36-ma per tube. EL-34s? 38-ma per tube.
PostPosted: November 18th, 2026, 8:57 am
Shashi,
Measured without power tubes.
Between pins 3 and 8 (looking down from top): -54.6V
Between pins 5 and 8: 536V DC
Reduced the bias current to 30mA bias with EL34 tubes installed. Manual recommends 150mA for EL34 and KT-88
Could the plate voltage be causing the problem?
PostPosted: November 18th, 2026, 9:36 am
Shashi,
A couple of things. First, the bias voltage measurement does tell me it probably has enough bias voltage for KT88 tubes. So that question is answered.
Second, the B+ voltage you read with the power tubes removed is the no-load voltage, which is NOT the voltage with the tubes installed. One really should not operate the amp without power tubes since the resultant voltage at no load could be greater than the rating of the power supply capacitors. I would expect a good design would use 600VDC rated capacitors or stack high voltage (350VDC to 450VDC electrolytic capacitors in series (with appropriate voltage balancing resistors) to functionally act as a capacitor with double the individual capacitor voltage rating in that event. But you cannot necessarily count on that. But that is a digression.
A shorted KT88 will cause the condition you observed. The biasing arrangement for your amp it based on a single fixed bias voltage for all the tubes, and the combined current measured at the combined cathode connection (likely across a fixed resistor). As such, it is not possible to isolate which tube is the culprit. So, yes, you will need to have the tubes tested for shorts. I would immediately contact the vendor you bought these from, describe the situation, and request a return and replacement with the new matched quad. Since the design operating current is 38mA for this amp, it is probably benefitable to make sure that the point for matching the tube is at this current and the B+ voltage for the amp. The test sheet with the tubes has an unusually low current at the -55V bias voltage. There is something to be said about getting quad matched tubes from a vendor that does matching at a number of different operating points (like the APEX matched tubes), since tubes may match at a single point but not across all the operating points. This is vital for an amp that has no individual bias adjustment or active autobias arrangement which can compensate on a per-tube basis. The most important thing for a PP amp is for the current through each tube of the PP pair being as close as possible, since this insures low DC current across output transformer.
PostPosted: November 18th, 2026, 3:40 pm
Thanks David.
Tested for shorts with a multimeter across the tube pins. No shorts detected.
I bought these tubes from AliExpress as I could not locate these tubes in any reputable sources, include China Hifi Audio. Shall return them.
I am using this amp to drive the supertweeter about 8.5kHz. Only reason I am using them is because I own the amp. Maybe I should replace it with a smaller powered SET like 45, 2A3, EL84 etc.
Which tubes serve best to drive horns with 105dB efficiency at high frequencies? My sonic goals:
1. Extended highs to atleast 25kHz
2. Detailed without harshness
3. Good soundstaging
PostPosted: November 18th, 2026, 4:51 pm
Shashi,
Well, the amp is definitely overkill as a supertweeter amp. It probably barely has the HF bandwidth you are requesting, the output transformers would have to be really good. I do not know why you need KT88s for this.
I don't know what I could advise. You do not need the power, a simple 1W SE spud amp using a 6C45P or WE417 using a small 5K OT 1W would work fine given 105dB efficient supertweeters. Otherwise, if I were you, I would just drive the supertweeter passively from the tweeter amp, using a first order filter with a single capacitor. Assuming the supertweeter impedance is 8 ohms, the capacitor would be around 2.2uF. Use an L-pad between the capacitor and the supertweeter. Adjust level to suit. The function of a supertweeter is providing "air", there is no FUNDAMENTAL musical signal this high. Basically we are talking about timbre of instruments containing a lot of upper harmonics like cymbals, other struck percussion and high brass/woodwinds. I would start there first and reevaluate whether you actually need to have an amp for this.
PostPosted: November 18th, 2026, 7:43 pm
David,
Yes, I dont need the power of KT-88s. Was planning on keep using the superamp, but wanted more sparkle and refinement at the top end over JJ EL34, so ordered the latest iteration of Linlai KT-88s.
I have a 5-way active horn system. I am not inclined to add L-pads and caps into the signal path.
1W spud amps sound appealing. Any recommendations?
PostPosted: November 18th, 2026, 8:27 pm
Spud amps are DIY only. There are schematics floating about. Any tube that has a low plate impedance can work. The usual suspects are tubes like the 6C45P, 417, 6H30, 6N6P, 5687, etc. For double triodes you can run both sections in parallel. B+ will be low feeding through an output transformer, maybe around 150VDC, which can be easily achieved using a small power transformer. Biggest problem is finding a suitable output transformer for the job, it may take some looking around and innovative thinking (you do not need LF response, but it still has to work with 15 to 30 mA of idle current).
A capacitor and L-Pad will have less in the signal path than an amplifier. Remember that the power supply is part of the signal path for an amplifier, so it means the signal is going through some large electrolytic capacitors. Sometime simplier is better.
PostPosted: November 18th, 2026, 9:06 pm
David,
Tell us about the amp driving the tweeter just below this super-tweeter. It's HF response might be better than many alternatives, or not.......
