November 18th, 2026, 10:27 pm
FerdinandII wrote:
Tell us about the amp driving the tweeter just below this super-tweeter. It's HF response might be better than many alternatives, or not.......
November 18th, 2026, 10:39 pm
November 18th, 2026, 11:02 pm
FerdinandII wrote:I was just thinking it might be beneficial to run the AES/Cary with good EL34s on the upper mid and swap that amp to the super-tweeter.
So......what amp is driving the upper mids?
Is swapping a possible approach?
November 19th, 2026, 12:12 am
Cogito wrote:Thanks David.
I am using this amp to drive the supertweeter about 8.5kHz. Only reason I am using them is because I own the amp. Maybe I should replace it with a smaller powered SET like 45, 2A3, EL84 etc.
Which tubes serve best to drive horns with 105dB efficiency at high frequencies? My sonic goals:
1. Extended highs to atleast 25kHz
2. Detailed without harshness
3. Good soundstaging
November 20th, 2026, 12:05 pm
November 20th, 2026, 12:48 pm
dberning wrote:Shashi-
If you wanted my help on testing the tubes, I can do. It appears that this amp has a partial fixed bias and partial cathode-bias arrangement? And I assume that the recommended bias current of 150 mA is the combined current for all four tubes?
Dave
November 20th, 2026, 4:04 pm
Dave
