It is currently July 7th, 2026, 6:43 am
 Post subject: Re: Acknowledgement
PostPosted: July 6th, 2026, 1:41 pm
Agreeing with Grover. I've also had leakage issues with some, eight others have never leaked. Just grab a little epoxy and seal the ends. Problem solved and great sounding caps.
Grover had another cap recommendation that has worked well for me: Cornell Dubilier Knowles 942C series. Look for the highest voltage available.
https://www.digikey.com/en/products/filter/film-capacitors/62?s=N4IgjCBcoEwAwBYCcVQGMoDMCGAbAzgKYA0IA9lANohwB0YABAK0BiIpdYArM2x7TBi92NWggDswgLqkADgBcoIAKoA7AJbyA8pgCyhbPgCuAJ0IgAvqQC0MVCAyR5JoyXJUQXEFKshrEaAcsPCJSCkhqAGZIgA5vX2sEe0ccAjdw6jA4JG54iwsgA
The catch is, they don't sell a 0.33uF. Depending on the circuit, you may be just fine with a 0.22 (LF Rolloff?)or 0.47 (stability?) Or, you could parallel a 0.1uF & 0.22uF.
PostPosted: July 6th, 2026, 2:30 pm
Well, if you're going to try the Cornell-Dubiliers you can go up to 1uF. The only reason I recommended the smaller Miflex is because the 1uF's are just so enormous. They won't fit on the board but you could off-board them to a terminal strip. But they're also pretty expensive.
Users browsing this forum: No registered users and 130 guests
